Re: valve lash/timing
Posted by CNKS on July 17, 2007 at 20:08:44 from (204.249.178.32):
In Reply to: Re: valve lash/timing posted by Mark Doud on July 17, 2007 at 18:30:50:
Assuming that is an IH publication I will take your word for it. However, I believe the C123 has all 6 digit serial numbers, and that the 0.020 applies to one of the later engines, but I don't know for sure. I don't know where the serials started for the C135-up. Perhaps someone will read this and clarify. I am not familiar with the C135 tractors, the earliest, I believe is the 330, followed by the 340.
