Re: valve lash/timing
Posted by Mark Doud on July 17, 2007 at 18:30:50 from (71.58.88.206):
In Reply to: Re: valve lash/timing posted by CNKS on July 17, 2007 at 18:07:18:
I got the numbers from:
Service Manual
Engine & Fule System.
c123, c135, c-146 & c153 Revision 2 March 1977
Page. 1-18
Tappet clearance is marked with a symbol that has a comment associated with it that says:
Engines with Serial Number 95097 and up .014 intake, .020 exhaust.
Mark D.
