706 CLUTCH PROBLEMS-PLEASE HELP??
Posted by BIG RED 1 on July 19, 2007 at 08:13:34 from (71.217.218.31):
706 GAS WIDE FRONT.AFTER MOWING FIELD,PULLING ON TO ROAD SHIFTING FROM 2ND TO 3RD,AND 3RD TO FOURTH THE TRACTOR WILL HESITATE FOR 2-3 SECONDS AND GRAB THE CLUTCH OR GEAR THEN PULL THE FRONT END OFF THE GROUND AND THEN DO AS IT SHOULD(SOME TIMES 2-3 TIMES) THE CLUTCH SEEMS TO BE THE SORE SPOT.
THE TA IS IN HIGH AND THE OWNER NEVER USES IT.
THE PTO IS NOT ENGAGED EITHER WHEN THIS HAPPENS.
AND IDEAS? AS ALWAYS THANKS IN ADVANCE
RANDY
