Re: 706 CLUTCH PROBLEMS-PLEASE HELP??
Posted by Kevin Meier on July 19, 2007 at 13:52:01 from (64.71.85.247):
In Reply to: 706 CLUTCH PROBLEMS-PLEASE HELP?? posted by BIG RED 1 on July 19, 2007 at 08:13:34:
i found some troubleshooting stuff on a web site
JUMPY ENGAGEMENT OR POOR RELEASE. A. DISC BENT (TRACTOR FORCED TOGETHER OR DISC DROPPED).
A. GRIND FLYWHEEL TO CORRECT SPECIFICATION.
B. DISC DISTORTED FROM HEAT (EXTREME SLIPPAGE). B. B. REPLACE DISC.
C. PPA NOT ADJUSTED CORRECTLY. C. REPLACE PPA OR CORRECT ADJUSTMENT SPECIFICATION.
D. FLYWHEEL NOT GROUND TO CRANK D. GRIND FLYWHEEL TO CORRECT SPECIFICATION.
E. 86 SERIES CAB MOUNT WORN EXCESSIVELY.
E. REPLACE CAB MOUNTS.
F. F. RELEASE LEVER CRACKED OR BROKEN. F. REPLACE PPA OR RELEASE LEVERS.
G. PPA PIVOT BLOCK LOOSE. G. REPLACE PPA.
H. DISC BINDING ON INPUT SHAFT. H. CLEAN DIRT AND GRIME FROM SPLINES. IF SPLINES WORN, REPLACE DISC.
I. PPA NOT FLAT IN FLYWHEEL. I. INSPECT FLYWHEEL TO INSURE PPA MOUNTING SURFACE IS NOT TAPERED ALLOWING PPA TO BE DRAWN DOWN UNEVENLY.
J. FAULTY PILOT BEARING. J. REPLACE PILOT BEARING.
