Re: Bob M, I need your help
Posted by Janicholson on July 21, 2007 at 15:51:21 from (66.173.50.147):
In Reply to: Bob M, I need your help posted by Paul Shuler on July 21, 2007 at 15:28:42:
There is nothing that I see that is wrong. When you say turn over, are you saying the starter does not turn, or are you saying it does turn, but will not start?
If no crank, it is not the wiring, The battery is either dead and gone "posts up" (possible) or a connection/wire has corroded or loosened. the heavy wire going to the big starter switch, and the heavy wire going to the starter from that switch, and the ground cable are the only things in that circuit ever.
If it spins, the issue may be the switch in the handy box shown in the pics. If the lead going there gets chafed to ground, it will not start due to a grounded mag.
The Mag is grounded (as you indicate) to kill the engine. Disconnect the wire from the side of the mag and then there should be no reason it would not get fire. Keep us informed, we will respond JimN
