F-20 Rod bearings
Posted by Greg NE on July 21, 2007 at 15:59:55 from (67.141.102.24):
Do any of you know if there is a source for new rod bearings for a F-20? I have a friend that is going through one and he has a bad bearing but at least the crank is still smooth. Thanks in advance Greg NE
