Re: F-20 Rod bearings
Posted by El Toro on July 21, 2007 at 17:16:53 from (152.163.100.138):
In Reply to: F-20 Rod bearings posted by Greg NE on July 21, 2007 at 15:59:55:
You can try the thefordsonhouse in MI. You should have the rod journal measured to see if the
journal has been ground undersize. Rice Equipment may have some parts too. Their number is 814-327-9200. Hal
