Re: H log skidder
Posted by Bob Kerr on July 26, 2007 at 21:40:17 from (64.12.117.137):
In Reply to: Re: H log skidder posted by georgeky on July 26, 2007 at 20:39:53:
Hi George, Yep, it is more how you do it that what you do it with. I have a little 024 shihl I cut everything with. If it is bigger than what I can do with the saw, I use a good ol fashioned crosscut. That cross cut has saved me a ton of money since it is rare I have to use it and you know what the big saws cost. This tree I just flat read wrong. It had a slight "S" bend to it and not much of a top.I thought it would go one way and it decided to go the opposite when it finally did go. I looked at the stump and there was only a half inch of vertical wood that was undercut, holding the tree up. It basicly just balanced on the stump and it is a 60 ft tree with no top mind you. I have to tell you the waiting on it to fall is worse than picking up a first date. There was no wind at all that day. That H really impressed me and I am almost thinking it might be a stronger engine than the M or at least close. I need to pull those plugs and check the pistons, I bet it has some "good ones" in there. It did use some oil though. I did some fiddling with the carb as I pulled logs up hill and I got it leaned out where it doesn't have black smoke under load and it wants a little choke when starting and it really runs nice when it warms up but after running hard it wanted to run on a bit when shutting it off. Maybe it just needs to get good and cleaned out. As far as the M goes, well the power steering started leaking like crazy one day and the next it just dripped a little. Also the 3 point lift wasn't working so good and it is driven off the PS pump. On top of that, the clicking noise is back in the clutch with a load on it.I have some figuring to do on it I think, but I need to get those logs loaded before they spoil.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
