Re: SOS I need help badly - starter elecrtical problem
Posted by Owen Aaland on July 28, 2007 at 16:41:29 from (65.165.246.55):
In Reply to: Re: SOS I need help badly - starter elecrtical problem posted by 888 on July 28, 2007 at 15:34:57:
What I suggested was a way to test the starter to eliminate that from your troubles. If your jumper cables are long enough you can just leave the battery in place. You could also leave the volt meter on the battery when you jump the starter to verify that it does drop way down which could indicate a bad battery or a shorted gen/motor. I am not familar with the switch on your Cub but if one side is coming from the battery and the other goes to the start/gen, then shorting across those two terminals should cause the starter to spin. You can use your voltmeter to test for voltage drop along the circut. If in the start position you only have .06 volts at the A terminal on the gen/starter, I would just hold it in that position and start checking all the circuts. Start by making sure you still have good battery voltage in the start position. Checking each wire and connection you shouild have no more that .1 volt drop in any wire and no more than .2 volt across any switch. Either the Generator A terminal will have battery voltage or you will find the open circut. Do not overlook the ground path. In the start position there should be be no more than about .2 volts between the gen housing and the neg battery post. If the battery voltage is still over 12 volts with starter engaged you will find some place where there is a big voltage drop.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
