Re: 450 Fast Hitch Adapters
Posted by georgeky on August 01, 2007 at 05:58:07 from (64.12.117.137):
In Reply to: 450 Fast Hitch Adapters posted by David Robinson on August 01, 2007 at 05:48:12:
Yes you need the the straight ones. The ones you have are for category 2 implements which are 32 inches. There is a sway control arm for the hitch. There should be a couple of pull pins in it. You remove the pins for plowing or other ground engaging work. This makes the tractor steer easier with the plow in the ground and prevents damage to the hitch parts. If you are not plowing you will never really need to worry with that.
