Re: 1066 trans
Posted by Owen Aaland on August 01, 2007 at 22:34:05 from (65.165.246.212):
In Reply to: 1066 trans posted by ih460puller on August 01, 2007 at 21:46:00:
The MCV pump provides the lube for the transmission and differential. Transmission is lubed by the TA lube circut. The differential is lubed by the return oil from the oil cooler. Bottom shafts are lubed by being below the oil level.
