Re: 1066 turbo won't go into reverse
Posted by Owen Aaland on August 02, 2007 at 11:56:32 from (65.165.246.212):
In Reply to: 1066 turbo won't go into reverse posted by rockwood84 on August 02, 2007 at 11:49:38:
If the problem is in the verticle shaft in the transmission, the most likely cause is the bottom of the fork is broken so that the shift collar is only being operated by the top of the fork. This causes the collar to stick on the gears rather than sliding smoothly.
