Re: M engine - How would you build it?
Posted by the tractor vet on August 08, 2007 at 12:59:26 from (75.19.124.211):
In Reply to: Re: M engine - How would you build it? posted by georgeky on August 08, 2007 at 09:05:22:
Well George Vernon's S/MTA will knock down over 93 hp on the dyno at rated RPM and will run wright with Eugene's 706 and on the 352 N H grinder she will run eared corn thru the small screen like you said as fast as ya can shovel . Before we put the rebuild to her she was maken over 75 Hp and it had enough to blow the gear box on the I H corn chopper when Vernon tryed to show off by choppen in second never missed a beat but the gear box looked like someone stuff a handgernade in it and pulled the pin. Even sounded like it . Oh well we needed a new chopper anyhow .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
