Re: Georgeky and Hugh MacKay..........Iiiiiiii did it! :)
Posted by Hugh MacKay on August 09, 2007 at 18:08:26 from (209.226.247.173):
In Reply to: Georgeky and Hugh MacKay..........Iiiiiiii did it! :) posted by Patrick Martin on August 08, 2007 at 20:29:59:
Patrick: Great responce you got here, just about all of them I have talked with from time to time about offset tractors. There are a few of them missing but for the most part you have the cream of the offset crop. Since I've become obsolete, this will allow me time for a YT vacation. But it could get worse, just be on the lookout for a burgendy Buick in your driveway.
Scotty, your the most likely candidate, mumma wants to stick her toes in salt water, coming or going one or the other will be across NY, VT, NH, MA and ME. Not going to happen until Oct.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
