Re: Ignition switch on a Farmall A
Posted by Janicholson on August 09, 2007 at 21:33:29 from (71.87.39.51):
In Reply to: Re: Ignition switch on a Farmall A posted by dave guest on August 09, 2007 at 21:23:00:
If a mag, the switch is grounded so it will ground the wire going to the magneto when pushed in. If coil ignition, the switch provides power from the generator side of the amp meter, to the coil when pulled out. Way different switches. JimN
