Re: I-4 Hitch
Posted by Wardner on August 10, 2007 at 09:45:39 from (4.154.245.54):
In Reply to: I-4 Hitch posted by Harold H on August 10, 2007 at 08:35:37:
Does the center piece have 9004 D cast into it? Does it allow the spring-loaded pintle to shift/rotate slightly from side-to-side?
This set-up is on my ID-9 which is a parts tractor. I am sure it is stock IH material. The odd thing is that it doesn't show up in my parts book. The book shows a standard drawbar and bolt-on pintle. It's not much different than what is currently available at a truck parts outlet.
I won't be able to take a picture until the 15th. Let me know if you want a picture. Meanwhile, I'll check to see if I have anything in my computer.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
