Re: Re: Super A , magneto timing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Jim Becker on February 13, 2000 at 09:25:04 from (209.30.171.179):
In Reply to: Re: Super A , magneto timing posted by Chris Auer on February 12, 2000 at 18:55:15:
If the timing gears are all properly set and you follow the manual's timing procedure correctly, everything will work fine. From your description, it looks like you got in trouble with "turned crank until the impulse deal tripped," which the manual didn't tell you to do. That was probably 1/2 turn, at which point you needed to go another 1/2 turn, not a full one. You have to go a full number of turns (in total) or you won't have the timing mark back in line. Following the manual, you will actually be at cylinder 4 when you set the timing.
Post A Followup
: Re: Re: Re: Super A , magneto timing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
