Re: Super A , magneto timing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Chris Auer on February 12, 2000 at 18:55:15 from (205.188.198.43):
In Reply to: Super A , magneto timing posted by Carl on February 12, 2000 at 17:04:19:
Some grease is required. At one time there was an IHC magneto grease for those gears. The notch should line up with another mark on the other gear. For reinstallation, I wound up putting the mag in with rotor pointing to #1, @ tdc piston #1. I turned crank until the impulse deal tripped, then rotated 1.5 revs. This is what it took to get a spark on the #1 wire @ tdc of #1 piston. The 1 rev the manual called for got me spark @ tdc of one of the other pistons. I assumed a mistake in manual. What a pain in the ass figuring that out was. Anybody's manual say 1.5 rev vs 1.0 rev?
Post A Followup
: Re: Re: Super A , magneto timing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
