Re: Farmall B - timing the engine when...
Posted by Patrick Martin on August 12, 2007 at 16:37:51 from (64.154.26.250):
In Reply to: Re: Farmall B - timing the engine when... posted by Dave H (MI) on August 12, 2007 at 15:12:41:
Well if you are wanting to pull your distributor and re-stab it into position then there is an easy way to do it.
I don't remember if the distributor gear is helical cut or not but assuming that it is then you need to be sure to mark the location of the distributor housing on the block and on the distributor base with a black marker. Just a line will do. Pull the distributor out, the rotor will turn counter-clockwise a bit when you do. Now mark where the rotor is pointing on the edge of the distributor so you have this position logged.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
