multispark problem
Posted by noidea on August 14, 2007 at 18:24:03 from (71.79.45.224):
What is wrong with my Summit Racing multispark ignition box. All of the wires are hooked up correct according to instructions. It would run on what seemed like two cylinders for about ten seconds. Now it won't start period. The light flashes when you turn the key to indicate that the unit is functioning properly. When I crank the engine the light doesn't flash as it should. This according to the instructions means that my pickup method isn't working. The white wire is connected directly to the post coming out of the distributor. What is wrong with it?
