Hydraulic Pump for 140 vs 200 interchange
Posted by brmtdg on August 15, 2007 at 20:38:09 from (206.229.248.251):
Have a 140 that the hydraulic pump failing to generate sufficient pressure. The lift is slow and weak especially when cold .The tractor been quite heavily used over the years. Found a used pump from a 200 and wonder if they would interchange? I know I would probably be better off to bite the bullet and buy a new one for the 140 but as always trying to save a couple of dollars since it not used as much as it once was.
This forum has been a great help!!!
thanks in advance...
brmtdg
