As simple as the pumps are I would open it up and take a look. I have seen a few pressure relief valve springs that were broke cause a weak lifting problem, all would not lift till the engine RPM was extremely high with a heavy load on the lift. Last thing most folks would think to check would B the filter/screen.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
