MW Hand Clutch on an M
Posted by CP1 on August 22, 2007 at 08:39:17 from (66.172.236.74):
Just wondering if anyone is familiar with the M&W hand clutch used on a '47 M with band brakes. It is slipping and full of grease on the discs, so the seals are leaking. Is there adjustment on this clutch? I tried to tighten the center nut before I took it apart but was already tight. Would convert back to the regular brake without the clutch but I believe the bull gear has to come out etc. to change the bull pinion shaft? Thanks in advance!
