Re: GL Rating on Gear Oil for M
Posted by Bob M on August 22, 2007 at 10:49:25 from (151.190.254.108):
In Reply to: GL Rating on Gear Oil for M posted by Clarkbug on August 22, 2007 at 09:26:43:
The M transmission contains only straight cut spur gears and single straight cut bevel set (differential drive gears). Consequently a GL1 rated lubricant is entirely adequate.
GL2 is OK too - it's essentially GL1 with some added rust/oxidation inhibitor.
GL3 and higher rated oils contain EP (extreme pressure) additives. These are intended for highly-loaded hypoid and spiral bevel gearing. These additives are unnecessary and may be actually harmful to the "stone age" transmission in an old tractor. (Some EP additives cause INCREASED friction and wear in low tooth pressure-loaded spur gearing such as is in your M)
Bottom line: Buy the cheap GL1. It's a far better lubricant than the best that was available back when your M gearing was designed!!
