A Engine
Posted by Gene37 on August 26, 2007 at 16:33:21 from (67.77.120.67):
Just overhauled the A engine and it ran just fine. Now we have a knocking noise from the engine. Took the oil pan off and the rod and maim bearings look ok. We suspect the carb. or Mag to be the problem. All help is appreciated.
Gene
