RustyFarmall said: (quoted from post at 11:53:19 08/27/07) There are supposed to be three nuts with the cotter pins, all the same, and likewise all 3 springs are identical. Someone has used flat washers as spacers because either the stud would not screw into the tank far enough, or the nut would not go onto the stud quite far enough. Originally there would have been NO washers.
hmm,, Maybe I can go strip the '39 at the junk yard.
Did M's use the same sized attaching hardware? Just in case the junkyard doesn't want to part the hardware from the tank.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
