Mike, I'm not sure if the hardware is the same on an H as on an M, I'll have to check on that. Those slotted nuts are called "castellated nuts" or more commonly referred to as "castle" nuts, and should be readily available at just about any hardware or automotive store. You might even find the springs you need at a GOOD hardware store.
One other thing, the nut is supposed to come off of the stud, with the stud remaining in the tank, but more often than not the entire stud/nut,spring assembly will unscrew right out of the tank. Don't worry about it. You can clean it up and re-install just the way it came out, or work it over, get the nut to seperate from the stud, clean it all up and install the correct way. As long as you get some compression on the spring, your tractor won't really care one or the other.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
