Re: Farmall H front wheels wobble
Posted by Bob Kerr on September 03, 2007 at 20:48:27 from (205.188.116.73):
In Reply to: Farmall H front wheels wobble posted by Dalton S. on September 03, 2007 at 19:28:15:
Drive one tire up on a board so the other is off the ground, and spin the free tire and see what it does, then do the same with the other side. Also check the spacing from the rim to the wheel center and make sure they are even all the way around. A bent rim can act things up and a rim that isn"t centered will cause up and down bounce. There are other parts like the bolster that can mess things up too, but I haven"t had experiance there yet, maybe someone who has can fill us in there.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
