Farmall H front wheels wobble
Posted by Dalton S. on September 03, 2007 at 19:28:15 from (70.41.44.67):
About a month ago, I put my newly restored narrow front Farmall H in a local parade. When the parade was done, I had to drive it back to my grandmas house, so I put it in road gear and went the 1/4 mile or so to her house. When I got about half way there, I noticed the front wheels were wobbling really bad. I shifted the tractor down to forth and go it to the house. I took one of the hub caps off and took the outside bearing out. Well it came out in a dozen or so pieces. So I replaced the inside and outside bearings on that side, and just repacked the ones on the other side since they were still good. When I took it for a test drive the wheels still wobbled really badly in road gear, but are fine in fourth gear. What is wrong? I know it isnt the worm gear steering thing because the tires dont wobble together. I want to resell the tractor, so I want it to be fixed properly. Any advice is greatly appreciated.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
