Re: Farmall H front wheels wobble
Posted by jonnny2006 on September 04, 2007 at 07:09:37 from (72.171.0.145):
In Reply to: Farmall H front wheels wobble posted by Dalton S. on September 03, 2007 at 19:28:15:
my 43 H wobbels so bad in 5th that when i go to bed at night my arms are still shaking!! Mines is in the worm gear, cause everything else is good. when i greased the front it wobbled way worse as now it was lubed good. I would fix it but i only use the tractor for mowing the yard. I like to mow in 1st or 2nd as it gives the best cut at that speed. I also used to haul wagons for the neighbor with his M and it was 4 miles to the silo and i remember the wheels wobbling so bad that my hands hurt. The most common problume that i have had and that i.h. guys tell me... the worm gear gets worn bad in one spot, thus the wobbling. my 43 H will only wobble if it is in the bad spot. so if im on gravel and there is a good grade on the road i have to keep the wheel just left enough to get me into a good spot on the gear.
