Re: New member, sort of, and a new Super M
Posted by Chris NW Ind on September 04, 2007 at 07:18:14 from (64.136.26.226):
In Reply to: New member, sort of, and a new Super M posted by Chris NW Ind on September 02, 2007 at 19:29:02:
I did take the time to check out the entire front when I flipped the gear around. The bearing behind the nut is tight, no slop. I didn't check the wheel bearings up in the air, but they both seem tight. The u-joint is snug. Without a doubt the upper bolster bushing is wore. I could see the gear move back and forth when I turned the steering shaft with vice grips.
Anyhoo, I've only managed one really good look over of the SM. My next day off, I'll be doing a little disassembly and try to get it charging.
Bob, I'm not going anywhere this weekend. Got work to do and steel to make.
Chris B.
As an addendum to this Super M adventure, I just picked another '53 SM that was a restoration not finished/barely started. Same stuff as mine except somewhat tore down. Bought it sight unseen. I'll save that project for a rainy day.
