Re: Farmall H front wheels wobble
Posted by Janicholson on September 04, 2007 at 11:04:36 from (199.17.6.122):
In Reply to: Farmall H front wheels wobble posted by Dalton S. on September 03, 2007 at 19:28:15:
If the bearing came out in pieces, there could be spindle wear that allows the inner race to be loose on the shaft. OR The outer hub can be wallowed out, again excess play. Centering the wheel as noted in the other post is important. Finding all the lost motion in the gears shafts anf U joints is also a huge factor. A not permanent solution is to run one tire 5psi underinflated. JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
