Posted by Bob M on September 06, 2007 at 12:31:43 from (151.190.254.108):
In Reply to: Can't get timing right posted by IndianaRed on September 06, 2007 at 12:10:39:
Red - Sounds like you've got a pair of plug wires (#1 and #4) reversed. Correct distributor plug connections work clockwise around the cap in this order: 1-3-4-2.
#1 is usually marked on the cap. However if the distributor or distributor timing gears are installed wrong, #1 may not be where it's marked. If this is suspected, set the crankshaft so #1 is at TDC compression then note the position of the rotor under the distributor cap. Whatever terminal it points to will be #1 for your tractor. Then simply reconnect the other plug wires in the 1-3-4-2 sequence as above.
Incidentally it's highly unlikely fuel is not getting to #1 and #4 cylinders!
Swapping coil polarity should have no effect on coil heating. (It'll work fine either way...). Rather coil heating is usually the result of a 6 volt coil on a tractor that's been converted to 12 volts without the addition of a voltage dropping ballast resistor.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
