Can't get timing right
Posted by IndianaRed on September 06, 2007 at 12:10:39 from (76.215.34.12):
Got my H running this morning, on just 2 & 3, 1 and 4 no go.
#1 cylinder at TDC, rotor is at #1 terminal. Wired distributor starting there to #1, then inboard to #2, back to #4, outboard to #3.
Spark and compression good to all. Is there a chance no fuel to just two cylinders? Manifold looks ok.
Also, coil was getting hot. Read some through the archives, switched polarity, seems better.
Need some input please.
Brian
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
