Re: Farmall B - carb
Posted by Dave H (MI) on September 17, 2007 at 15:21:43 from (205.188.116.73):
In Reply to: Re: Farmall B - carb posted by RustyFarmall on September 17, 2007 at 15:12:44:
Actually, I was reviewing my archives today on the B and it would appear that you are very much a help! I think I can rule out ignition problems unless maybe I fouled my plugs a little with all this goofing around I been doing and I don't think I have a problem with fuel starvation 'cause pretty much every component betwixt the tank and the carb is new or been cleaned but it would be easy 'nuff to check. Vacuum leak would be like where? Around the throttle shaft or elsewhere on the carb? Maybe I need to recheck my bolts?
