Posted by Janicholson on September 17, 2007 at 16:48:25 from (66.173.50.156):
In Reply to: Re: Farmall B - carb posted by Dave H (MI) on September 17, 2007 at 15:21:43:
The vacuum leaks (if any) will be at the carb to manifold connection, the manifold body (rust holes, or cracks External, or cracks internal into the exhaust passages), or the manifold to head connection. If you have a leak of this nature, and have the idle speed screw turned enough to make it run fast enough to stay running, the idle mixture screw (that now does nothing) will do nothing. Check as follows. Use a propane torch with the burner off of the short pipe so that pure propane comes out. With the tractor outside idling, open the propane valve to what would be a medium flame (not way open) and keep the bottle lower than the valve to prevent venting liquid propane. Apply this fuel source to the places mentioned above with some care to be sure to cover all areas. If there is a leak, the engine speed will change abruptly, causing an increase in speed. If none are found, and the timing is correct, then fuel delivery in the carb may still be the cause. They are very tough to repair and can be hair pullers. If the manifols is cracked internally the only way to find it is visually with it off, or with all ports plugged, and pressure in the exhaust port it will hiss through the intake. Very best of luck, JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
