Breakthrough!
Posted by Mike CA on September 20, 2007 at 20:14:34 from (76.239.186.212):
I got through the ton of dried clay stuff in the sediment bowl top! I soaked it in carb cleaner for a day and pulled it out and drilled it out, scrubbed it out, and scraped it out any way I could. I got fluid to flow through it all the way.
So, back in for more soaking just to make sure I get it as cleaned out as possible. Now all I need is a gasket and it's good to go!
I'll eventually replace it with a duel line carb, but at least I don't have to spend money on this one to get it running.
Was there any sort of gasket at the shut-off lever? It seems a bit loose when I open it up to get fluid through it. I'm worried it will leak. Is it supposed to shake when opened up?
