Re: Breakthrough!
Posted by HENRY E NC on September 20, 2007 at 20:22:08 from (216.119.6.86):
In Reply to: Breakthrough! posted by Mike CA on September 20, 2007 at 20:14:34:
Mike here should be a nut betweeb the lever and the bowl. Tighten it gently . if it is still loose use a little paking behind it. You can buy that at the hardware in plumbing Henry (thought all sailors knew how to pack a shaft) heh heh
