Re: Surging RPM on 706
Posted by KBrochman on September 25, 2007 at 20:29:22 from (206.8.88.78):
In Reply to: Surging RPM on 706 posted by KBrochman on September 25, 2007 at 18:25:53:
guys thanks for the info,I did put the carb back to stock and tried all the other things you mentioned,the timing is at 27 degrees btdc at hi idle it seems to run better I have not tried 93 gas yet can that stop the surging? I've seen other ones run good on regular Thanks
