Posted by KBrochman on September 25, 2007 at 18:25:53 from (206.8.88.78):
Hello, I have a 706 gas w/ a 263 engine. It runs great, but when I put a load on the engine the RPM drops a little and the govenor seems to over compensate and the engine RPM surges. Pulling out the choke helps. So I tried richening the main jet, that helped a little but, it would foul plugs. The engine has new points, plugs, cap, rotor, wires, and rebuilt carb. The fuel supply to the carb is good, the timing is set at ten BTDC and the advance works good. I adjusted all the carb and govenor linkage as per the IT manual plus replaced the springs. I disassembled the govenor and that is in good shape and I tried to adjusting the buffer screw, but none of this helped very much. I by passed the resistor by the coil, this seemed to help but not fully fix the problem. I wonder if I need more voltage, it has 13 volts at the battery at high idle. I'm thinking about putting and altenator on it. I got the tractor this way and have no history on it. Im stuck, any help would be greatly appreciated. Thank You!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
