Farmall A erratic running
Posted by csmeyers on September 26, 2007 at 17:46:43 from (76.182.76.19):
My A starts right up and runs smooth, however when put the tractor under a load or fast throttle advancement it will run very rough. It sounds like it is not running on all 4 and I do notice dark smoke from the exhaust stack, when I pull back the throttle it will run smother. I just went through some Mag resetting, but I don’t think that is it....or may be it is. I need some of you Farmall experts to give me some suggestions. Also what should the original Generator put out, I know a car alternator will put out about 14 volts, will a 6 volt generator put out 8 volts. My amp meter is not working, but I can see the contacts closing on the regulator so I am some what sure the generator is working.
