All modern oils have detergents in them - detergents keep the "junk" suspended in the oil so it gets caught in the filter and drained out when you change oil.
The exception would be oil that is specifically labeled "non-detergent" which can still be found. DO NOT USE THIS NON-DETERGENT OIL. There is a 99.9% chance that your tractor has already been run with regular, detergent oil.
If you are concerned about "junk" in the pan, block, and valve cover - remove the oil pan, valve cover, and side cover to take a look inside. If there is junk, scrape it out, rinse it out with a solvent of some type, etc. Put it back together with fresh oil (whatever you are going to use for the long-run) and run it. If the oil looks real dirty right away, only run a few hours and change it. After that, I would change it once a year at most for what you plan to use the tractor.
Which oil should you use? I stand by my suggestion for a diesel-rate oil (the zinc). We run the CaseIH 15w-40 in everything at home, never had an oil related failure in 40 years of running CIH oil. My brother runs Rotella in his Cummins pickups - the 98 has 175k on it and doesn"t burn a drop yet.
As for me, I know how much money I have into my overhaul and it will be Mobil Delvac 1 5w-40 as long as I own the tractor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
