Re: Starting oil suggestion
Posted by John M on September 28, 2007 at 03:34:46 from (209.213.22.170):
In Reply to: Starting oil suggestion posted by Mike CA on September 27, 2007 at 15:07:34:
You need to check with the guy you got it from and see when the engine was overhauled, if it was, and what oil he used. When in dought, use the non-detergent, then over time, work the detergent oil in. I had only one tractor I could not find out about, or didnt know about.I used straight non detergent on first oil change, then swapped a quart for one non detergent, then two, then three, so on and so on until I got to all detergent. This way, any sludge that may have been in there was SLOWLY disolved. I kept that tractor 9 years and not once had a oil problem, or ever dropped the pan on it.
