Hyd. Inlet Tube on 656-How Tough to Get To??
Posted by Wayne from Iowa on September 28, 2007 at 04:53:30 from (216.51.199.106):
My 656 Gear Drive Gas hyd system is full of air. The inlet tube must be off or out of position. The last owner said he changed the return hose in the transmission through the PTO. When I stick a wire in thru the hyd filter inlet opening it stays straight and does not curve down.I understand this tube curves down. Any problems or things to watch if I pull the transmission top cover? Any other things to look for with this hyd problem? Are there gears in the way to get to this tube?? Thanks for the help.
