Re: FARMALL 504 GAS ENGINE SWAP
Posted by Hugh Mackay on September 29, 2007 at 13:36:36 from (209.226.247.128):
In Reply to: Re: FARMALL 504 GAS ENGINE SWAP posted by richhenry on September 29, 2007 at 07:36:18:
Rich: parting out a 504 is a hard call, they didn't have sleeves, thus most of those engines are reaching the end of the line as far as rebuilding. The rest of the tractor holds up very well, thus there may not be big demand for the parts, other than the engine.
A working 504 with the D-188 diesel or a more reliable gas engine is still a very usable tractor, with IPTO, 3point hitch and forward operators platform. The 300 or 350 engine will be a direct bolt up at the rear. You will probably have to modify, front engine mounts, fan shroud assembly, breather, radiator hoses, etc. Shouldn't be too bad as engine will be close in size.
