Re: Full Engine Rebuild or IN-Frame, How do I Know ?
Posted by ed8844 on September 30, 2007 at 14:24:59 from (74.229.216.165):
In Reply to: Re: Full Engine Rebuild or IN-Frame, How do I Know ? posted by El Toro on September 30, 2007 at 13:47:55:
Thanks Hal - I've got the loader and backhoe off so its easier to work on -doesn't look like much without them. I have a clear shot at the lower end with the oil pan pulled -lots of room to work - Can it be measured and inspected without pulling the engine or is it best to forget it and pull the motor and take the crank to a machine shop? Buddy of mine says "If you gotta ask -You already know the answer"
Well I guess so.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
