Re: Plowing sod?!?! with Super C
Posted by Dave BN on September 30, 2007 at 14:56:24 from (64.12.116.73):
In Reply to: Plowing sod?!?! with Super C posted by Andrew Z on September 29, 2007 at 13:42:35:
Disc it several times before plowing, with the disc set almost straight. Disc both directions of the field. This will slice up the sod and it will break up easier when plowing. Have you used that plow before? If not you'll need to expirement a little to get it to plow right. How big is this plow? Heaver sod may require a sod buster plow, 20" or so. You should be able to pull that if your SC is in good shape but you will need 1st gear for that. You may be able to borrow one from an OLD farmer in the area. Yes it will get progressivly easier each time you work that field (at least twice a year) Dave.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
