Re: SOP for Pull Starting a Tractor
Posted by Janicholson on October 01, 2007 at 20:05:02 from (66.173.50.5):
In Reply to: SOP for Pull Starting a Tractor posted by Brian Jensen on October 01, 2007 at 19:43:26:
It could be as much as a half mile or more. Do not pull it faster in any gear than it would go in that gear, or it could damage the engine. Third gear at second gear speeds works. Make sure the clutch works correctly as well as having brakes. Use 3/4 on the speed control or more. White smoke means you are getting diesel fuel injected. No smoke no fuel.
Be sure the oil pressure is up, and go for it. JimN
