Re: Valve Adjustment Saga
Posted by Janicholson on October 02, 2007 at 13:06:37 from (199.17.6.122):
In Reply to: Valve Adjustment Saga posted by Brian Jensen on October 02, 2007 at 12:20:27:
Putting 6 psi (maximum) into the radiator with a cork/plug th make a seal, will cause coolant to be able to go through cracks and into places that show leaks. If pressurized, the pressure should stay for several hours. Green in the head (unless spilled there is manditory to repair(or stop the leak). Heads on these can crack from hot shutdown, low coolant, and freezing. Rep[air is possible, and done quite often. Good heads are hard to find. Drain a bit of oil out of it to see if any is under the oil in the Crank case. Use a flat feeler gauge to adjust the valves. JimN
