Re: Intermittent Miss
Posted by El Toro on October 03, 2007 at 15:32:15 from (205.188.116.73):
In Reply to: Intermittent Miss posted by Brian Jensen on October 03, 2007 at 14:53:49:
Are you sure the plug wires are in the correct firing order? Should be in this firing order if the rotor turns CW.
2-1
4-3 or in this order if the rotor turns CCW:
1-2
3-4
Hal
